How to determined if the number is belongs to 16:9 or not?
Some said 854*480 but in here, http://pacoup.com/2011/06/12/list-of-true-169-resolutions/ the number is NOT included.
Please give me a clue ... thank you.
Results 1 to 10 of 10
No, his list is right. The highlighted lines are exact 16:9 ratios. All the others, including 854x480, are approximations.
Why is it so important that you know ?
If you are encoding for DVD then anything wider than 1.33 (4:3) is a candidate, and anything wider than 1.66 should be encoded for 16:9. Most film material isn't 16:9. It is either 1.33, 1.66, or something wider than 16:9 - 1.85 or wider.Read my blog here.
You have a perfect 16:9 ratio when:
width / height = 1.777777777777777777777777777777777....
The sevens continue out into infinity.
But only when using square pixels. For example, with DVD 720x480 or 720x576 can be 16:9 because the pixels aren't square. There is a flag on the DVD (in the IFO files or in the VOB files) that tell the proper aspect ratio at which the video is to be displayed, 4:3 or 16:9.
Frame sizes like 704x400 (1;76) are close enough to 16:9 that you can't tell the difference without measuring the onscreen image. And if you have a CRT the aspect ratio of the TV is probably off by a few percent. So it's not worth worrying about.Last edited by jagabo; 19th Jul 2011 at 07:04.
Japanese 7680x4320 format:
http://www.nhk.or.jp/digital/en/super_hi/02_super.html
